Built Motor guys and gals
Old Dec 10, 2005 | 10:19 PM
Whitelighting's Avatar
What head and cam combo do you have making stupid HP@TQ ....with no issues...
thks Bob
Old Dec 11, 2005 | 11:16 AM
thks Bob
ttt
Old Dec 11, 2005 | 11:25 AM
camcojb's Avatar
thks Bob
I don't know what stupid HP/torque is but mine made 621/708 with ported heads and Stage II Crower cams from Dantes Performance.
Jody
Old Dec 11, 2005 | 01:12 PM
LatemodelRacer2's Avatar
i have whatever comes in a JDM longblock
Old Dec 11, 2005 | 03:31 PM
The Swede's Avatar
TRUCK OF THE YEAR - 2010
Good answer !
Old Dec 11, 2005 | 05:18 PM
Jody
Im hope mine will put those #s down i just bought the stage 2 crowers and ported heads,now i just need to find a bigger fuel rail you change urs?
Thanks for the post
Old Dec 11, 2005 | 06:11 PM
camcojb's Avatar
Thanks for the post
Stock fuel rail, but did go to bigger pumps, filter, adjustable regulator and 60# injectors.
Jody
Old Dec 11, 2005 | 06:36 PM
Neal's Avatar
HI!... Running FOX LAKE stage II heads :
- CNC race ported
- MANGANESE bronze guides
- FERREA S/S soduim filled one piece under cut 1mm larger valves, with 3 angle valve job. (5 angle not recommended for street use)
- CROWER "BEE HIVE" valve springs
- CROWER retainers
- FORD keepers
- COMP-CAMS custom ground billet cams (0.600/0.600 lift, 234/234 duration (set up for a turbo)
- Troyer titanium 9 thread plug inserts
- COMETIC heads gaskets
- ARP head studs TQ'ed to 92FT/LBS
Hoping to make 425H.P in N/A form at the FLYWHEEL.
Goal is 650RWHP with the T-76 turbo set-up i'm building.
