Gear change -help
Old Feb 11, 2000 | 05:03 PM
dogleg's Avatar
Question Gear change -help
I am not having much luck with getting those 4.10 gears in, the Baton Roughe SVt dealer sent the wrong gears so I am reordering.
I understand the speedometer will be off with the gear change,is that going to be my only worry? Is the computer tied to the gear change in any other way that will hurt the running of the truck.
Thanks for your input guys,
Alvin
Old Feb 11, 2000 | 09:51 PM
JIGAWATT's Avatar
Post
Dogleg:
I have had the 4:10's for awhile now, the only thing "off" is the speedo. Under lite throttle it will shift early, mid throttle is ok, hard or full throttle is right to redline.
JIGAWATT SVT#2698
N.L.O.C. Member
4:10's
Bassani kit
TransGo shift kit
AIM 2 inch drop shackle
Old Feb 11, 2000 | 10:02 PM
Metallic Blue's Avatar
Banned
Post
Jiga, What would the RPM's be at 158MPH with the stock 3:55's? The correct number for the 4:10's at 160MPH would be 5434RPM's right?
Old Feb 12, 2000 | 01:45 AM
JIGAWATT's Avatar
Thumbs up
Metallic Blue:
rpm's at 158mph w/3.55
6638rpm in 3rd
4647rpm in 4th "od"
rpm's at 160mph w/3.55
4705 in 4th
4.10's at 160mph
7764rpm's in 3rd
5434rpm's in 4th
Are you looking to do Silver State?
I know someone with a 6400 redline on their Lightning. But I'm not saying who
JIGAWATT SVT#2698
N.L.O.C. Member
4:10's
Bassani kit
TransGo shift kit
