Breslin or Stage 8 Header Bolts?
Old Dec 4, 2005 | 05:29 PM
TampaBlack99's Avatar
Am I correct for thinking the Breslin bolts seem much easier to install?
I need to replace the oem header bolts that keep backing out on me.
Also, is Summit/Jegs the cheapest place to buy them? $72
http://www.jegs.com/webapp/wcs/store...tegoryId=23317
Old Dec 5, 2005 | 09:32 AM
ttt
Old Dec 5, 2005 | 10:23 AM
cerucker's Avatar
I have the Stage 8's on my Cobra. They work real well!
Old Dec 5, 2005 | 12:46 PM
fullboogie's Avatar
I've used Stage 8 header bolts on 3 cars, and I love them. They can be a pain in the butt to install, but once done, you never have to touch them again.
Old Dec 5, 2005 | 02:05 PM
JollyGiant's Avatar
I got the breslins from jegs. They work great also.
Old Dec 5, 2005 | 02:24 PM
Bird's Avatar
I've used the Breslins on a couple of engines - no problems at all.....
Bird
Old Dec 5, 2005 | 03:03 PM
Thanks, I'm leaning toward the Breslin bolts.
Old Dec 5, 2005 | 04:23 PM
SILVER2000SVT's Avatar
With the Breslins you don't have to worry about keeping track of the clips.
I saw where they had a Stainless option too, but I probably wouldn't go that route. Being a 17-4 Stainless it will be substantially weaker than a heat treated carbon steel. Also with the set screw being stainless, that's a big no-no to use stainless on stainless threads without using a lot of antisieze to keep them from galling together and siezing up. Even the copper high heat antiseize has a hard time holding up with the kind of heat a header bolt sees.
Old Dec 5, 2005 | 08:47 PM
Fast95Z's Avatar
I got the Ford Racing/Stage 8's. Got them from either fordpartsonline.com or oemfordparts.com. They were cheaper then Summit.
