Gears and Rears
Old Feb 6, 2000 | 11:40 PM
Calightnin's Avatar
Question Gears and Rears
Please help me with a couple of questions. Is the L rear-end a standard 8.8 or a 9.75 as I have seen both mentioned here? Also after installing 4.10's.... I would like to get drag radials in a size (diameter) that most closely matches the size of our original tires. Anyone found the best match for this. If so what tire/rim combination are you using? Thanks!
Old Feb 7, 2000 | 07:39 AM
Yoda's Avatar
Post
Hey Calightning,
Do a 'search' on 'gears' then one on 'tires' & I think you will get more than enough info on both your ?'s
99' SVT Black Bolt NLOC #392
PSP Filter/chip
Clear Corner Lenses
Painted Calipers
Autometer Boost & Air/Fuel ratio Guages
best run 13.54 @ 101.35
**Ya it HURTS when you get struck**
