11.02 @ 120 Eaton powered ,no spray Eaton record!
Originally Posted by SVT F15O
Nice runs, I was there to see them.
You have some email BTW, sorry for the delay, I completely forgot. -Mat-
Josh
Originally Posted by QUIKSVT
thanks guys. Mods, well thats a long list, I'll just make a brief list here.
JLP shortblock
Patriot stage 2 heads (2 years old now)
JLP stage 3 cams
Apten ported Eaton ( 2 years old, I think Steig did this one)
Hand ported lower intake
Extrude honed upper
JLP ram air
PI converter
JLP valve body in stock tranny
JLP tuned, 50lb injectors, 255l pumps
Caltrac traction bars
JLP shackles, lowest setting
Bogarts all around
lund rollpan, and seat out, tailgate off.
I was seeing 16-17 punds of boost by the end of the pass. 60 ft was a 1.50
JLP shortblock
JLP stage 3 cams
Extrude honed upper
JLP ram air
PI converter
Bogarts all around
just wondering i have pretty much the same mods and just got truck running last night trying to figure out what i should run what size/kind of slicks are u running?
Originally Posted by ixcelr8
what pully combo are you using? you don't have long tubes/exhaust?
You said you lifted a head at 17psi? Is that all the motor can handle? Do you have ARP installed? I ask because I have the EXACT setup as you, without headers. If I come anywhere within .5 of your time I will be happy. But would have never thought that motor would lift a head.
Josh
did you stall engine up on take off? or did you flat foot it from idle on take off
