Plugs, intercooler, oil seperator...
Old Nov 17, 2005 | 01:12 AM
HalfTime's Avatar
Cool Plugs, intercooler, oil seperator...
First off, yes I did a search.
Holy crap you guys were not kidding, Spark plug removal and replacment is going to be a pain!!! Well, I need to put on a oil seperator, and after doing a search, I think cleaning my intercooler will be a good idea. From what I read, it is easier to change the plugs with the blower off, so I'll wait till I do that. What's the tourq specs and order for the blower?
I am a bit parinoid on the whole spark plug blowing issue... I have a pretty loud SVTL, even at idle it has a GOOD rumble. If a spark plug does start to lossen, will I DEFINATLY be able to here it inside the cab? On throtle, idle, what? Do I need a scope and check out each cylnder every week? Is thier an easier way to check them? All that smog crap is really going to be tuff to work around. Why they would enginear somthing like that, I don't know.
Any hints and tips quick off the top of you head please let me know... I am sick and tired of reading the endless search results.
p.s. I know I suck a spelling, If it wasn't for 'F7' I would be lostm but it doesn't work on line.
Edit
Also, does any one have pictures and information on a oil seperator set up that effectivly eliminates oil intake from both the drivers, and passengers side?
Last edited by HalfTime; Nov 17, 2005 at 02:56 AM. Reason: Oil Serperator question...
Old Nov 17, 2005 | 01:20 AM
Odellintulsa's Avatar
The right tools make the job easy.
3/8ths inch locking extensions set of 3 from sears.
3/8ths inch drive spark plug socket with the rubber boot on the inside.
3/8ths inch swivle socket wrench one that bends on the top.
1/4ths inch swivel socket set of 3 form sears
1/4ths inch 7 mm deep socket with an 3 inch extension for the coil pack screws.
magnet extension tool
You don't have to remove the blower.
