Bottom shroud underneath radiator...???
Old Nov 11, 2005 | 12:11 PM
shelpdoggSVT's Avatar
Hey guys and gals......
The bottom shroud has come loose from the front bumper and hangs down a bit. It is hardly noticeable, but it's driving me nuts!!!
Looks like the previous owner scraped a curb and sheared off a few of the plastic pins that hold it in place.
My question is....do I need that shroud there, or can I cut it away and be done with it. I can always refasten it with zip ties if needed.
Let me know....if you need pics, I can take some tonight when I get home. I will post them in between Martini's
Mike
Old Nov 11, 2005 | 05:33 PM
chucks bp's Avatar
If you are talking about the piece of rubber, it is important as it directs the air through the lower bumper opening into the aftercooler heat exchanger, without it the air will not be forced through the heat exchanger. Ford does not waste money on any pice that is not necessary. if it was not important they would have saved a dime and left it off.
Old Nov 11, 2005 | 07:12 PM
halflife's Avatar
i think you can get those push pins at autozone.
Old Nov 11, 2005 | 07:54 PM
the pins are not the problem....it ripped the rubber holes that the pins went into. I will put new holes into the rubber piece and zip tie it then.
I'm glad I asked before I did anything.....thanks guys
Old Nov 11, 2005 | 09:01 PM
silversvt04's Avatar
Try using a thin metal plate ( like a strip washer idea) and drilling the holes in it to coraspond with the factory holes.
Just my .02 idea
Russell
Old Nov 11, 2005 | 10:19 PM
Robert Francis's Avatar
I replaced that "flap" with a piece of plastic years ago - used the standard push-pins upfront to attach but I plan on replacing those with machine screws and nuts some day.
Old Nov 14, 2005 | 09:45 AM
brain bypass's Avatar
i did that a while ago. but then the rubber piece ripped off altogether. i am replacing it with a sheet of aluminum.
Old Nov 14, 2005 | 01:41 PM
That doesn't sound like a bad idea either....I have a machine shop here at work that could make that for me.
