Help please......coolant sprays out under WOT
Old Nov 8, 2005 | 07:57 PM
White01's Avatar
As the title says....under WOT coolant comes out of my overflow bottle. It sprays back toward my air filter causing the truck to die. What is causing this? Please help!
Rich
Old Nov 8, 2005 | 07:58 PM
LightningTuner's Avatar
Rich
That's usually an indication of a blown head gasket, or at least badly lifting heads. What's your setup?
Old Nov 8, 2005 | 08:04 PM
White01's Avatar
MP blower
Modular performance built lower
Ported heads
Crower stage 2 cams
8# lower
dynatech long tube headers
JL cold air
SBTB
FT total dominator converter
FTVB
NGK Br7 gapped at .032
cobra R water pump
160 thermostat
xcal 2
Sal, I don't have any oil in my coolant or coolant in my oil. No milkshake.
Rich
Old Nov 8, 2005 | 08:05 PM
PoorSvtMan's Avatar
exactly what he said. Mines doing this but still runs. Oil comes out and hits the exhaust and smokes and the coolant sprays out. But the coolant isnt mixing with the oil thank god. For now I just put a towl over the overflow cap so it wont spray everywhere. It runs good i just dont have the $$ to fix it
Mine only dose it under high boost or high rpms
Old Nov 8, 2005 | 08:20 PM
What's happening is your cylinder pressure is so high, that with the stock TTY head bolts, they are stretching under load and letting the heads lift. That allows cylinder pressure to blow into the coolant passages and blow it out the overflow. When you get off the throttle, the heads seat back down. I had this same problem years ago with the stock motor on my 01 and lots of spray.
Old Nov 8, 2005 | 08:27 PM
White01's Avatar
Sal, the truck has ARP head studs that were installed when the motor was built. Do you think its still the problem?
Rich
Old Nov 8, 2005 | 08:28 PM
PoorSvtMan's Avatar
Yea damn TTY bolts.. Owell ill drive mine for a few more weeks and get some parts gathered and then start tearing **** apart.
know any of the part numbers of things i might need?
sidriver2k@yahoo.com
Old Nov 8, 2005 | 08:46 PM
Rich
If that's the case, then maybe the heads and or block are not sqaure and it's not sealing well under high pressure.
Old Nov 8, 2005 | 11:26 PM
Casey02L's Avatar
Rich
Just because they are there does not mean they are right. Might not have been torqued correctly. You might try taking the valve covers off and checking the TQ on them. Might be too late, but never know.
Or there could be a block/head problem where it's not square.
