ported blower questions
Old Nov 9, 2005 | 09:40 AM
MaxPower's Avatar
Originally Posted by Stl01SVT
Before you remove the blower. Loosen the upper intake plenum, retorque the rear bolts first, then the front bolts. I bet this will stop the noise. It is very rare that the bearing go bad after a port job.
Also, try pulling the vaccum source to the boost actuator, and see if the noise goes away.
-Mike
Agreed. Stiegemeier's takes extra care when putting everything back together, and I know for a fact they inspect all prior to shipping. A lot of the added cost going with Stiegemeier is the "extras" they perform during R&R.
Also, as mentioned above, be SURE the torque specs and order was done correctly on the blower case when tightening it back down to the lower intake. Remember, the blower case is ALUMINUM, and can distort if not correctly torqued.
I'm sure Bob and Robyn will have you running perfectly. Give their shop the time to work with you - I know you'll be happy
Old Nov 14, 2005 | 12:15 PM
Slick_Sammy's Avatar
FAST95Z, hmmmm.... i heard my truck making the same noise this weekend with only a 2lb pulley and the new port. it had sat all day and was about 38 degrees when I cranked it up. I heard that avitation/bad bearing sound right after start-up when it was in gear and rolling through a parking lot under NO throttle. it went away after warm. I was in caravan of folks so I didn't have time to check it out thoroughly. i always garage my truck so this is the 1st time the engine has been started when the engine itself was colder than 55 degrees or so. let me know what Steige thinks of your issue b/c I may have it too. I'm convinced mine is cavitation.
Old Nov 14, 2005 | 01:02 PM
LTNDave's Avatar
Are your rotors stripped ( mine had the same noise, due to the incresed rotor to rotor clearance without the factor rotor coating, and once it warmed up it went away)
Also a stiege.
Old Nov 14, 2005 | 01:48 PM
Also a stiege.
mine are stripped.
Old Nov 14, 2005 | 06:56 PM
Fast95Z's Avatar
Stieg listened to the video and said "Can you send that back into us we need to inspect that." So I got to pull it off and put the stocker back on and then go from there.
