Metco Idlers
Old Nov 4, 2005 | 06:02 PM
Kyle's Avatar
Metco Idlers
Guys, IM trying to install 100mm Metco Idlers on my stock 99L and IM having some trouble. What is the trick to getting the belt back on? Will the stock belt even fit right? It seems to short to me. Thanks a lot for the help, Kyle
Old Nov 4, 2005 | 06:16 PM
LatemodelRacer2's Avatar
stock belt should fit fine....does your truck have stock upper and lower pullys?
Old Nov 4, 2005 | 06:20 PM
Kyle's Avatar
Yes it does, stock everything. IM just an idiot when it comes to this kind of stuff
Old Nov 4, 2005 | 08:30 PM
Spoyldrotn's Avatar
If you are stock, like me, you should be running 90mm pullies. I got a 1 inch longer belt (67"); however, if you break the tensioner tab off then the stock belt should fit. I'm sure that's your problem.....100mm pullies are too big. 100's are typically only used if you have a smaller upper pully.
Old Nov 4, 2005 | 08:40 PM
Kyle's Avatar
When you say tensioner tab, what exactly are you talking about? Thanks a bunch.
Old Nov 4, 2005 | 09:13 PM
kromdom's Avatar
tensioner tab
Kyle,
Link below for a quick read on how to break the tab off. Sorry, I have no pictures but you can locate this: you will encounter a "stop point" as you are releasing tension with your bar. That point is where you'll find the tab. Good luck!
http://www.nloc.net/forum/showthread...=tab+tensioner
Old Nov 4, 2005 | 09:55 PM
Kyle's Avatar
Originally Posted by kromdom
Kyle,
Awesome, Thanks a million!
