Eaton question
Old Nov 1, 2005 | 04:59 PM
moses Black 01''s Avatar
Eaton question
I was just wanting to make sure a eaton off of my buddies 99 would fit on my 01 (someone told me the boltpatern was different). Also who can i get to port my eaton, and i cant seem to get hold of wes.
Thanks for the help
Arren
Old Nov 1, 2005 | 06:02 PM
JimIII@jdm's Avatar
Former Sponsor
Thanks for the help
Arren
It is different but with the 99's there is room on to drill a hole to have the case fit the manifold. There are 8 bolts which hold it down, only 7 of them line up, but you can see that some of the case goes over the one hole so you can drill it there and bolt it down.
JimIII
Old Nov 1, 2005 | 07:24 PM
thanks man thats a start. Does anyone have any ideas on who are my options for eaton porting.
Old Nov 1, 2005 | 07:48 PM
kwilt's Avatar
Steig and LFP are the 2 that come to mind
http://www.lightningforceperformance.com/home.php
http://www.stiegemeier.com/index1.html
Old Nov 2, 2005 | 09:33 AM
brain bypass's Avatar
lethal performance does it also
Old Nov 2, 2005 | 11:57 AM
LatemodelRacer2's Avatar
go with steig on the port you wont be dissapointed
Old Nov 2, 2005 | 09:29 PM
SLVRLTNG's Avatar
you better check that case out, not all of them can be re-drilled. If it's off a 99 it may not be cast with the area needed to drill the holes. I have a case like that, it's probably one of the early cases...just a FYI...............JR
