Fuel filter question
Old Nov 2, 2005 | 06:10 PM
2tonOfun's Avatar
Originally Posted by bwkelley76
I have a feeling that if the filter is different than a regular f-150 then you should replece it with the original style. Bigger isnt always better, sure it may hold more junk, but it may not support the flow volume necessary for the larger injectors in the lightning. just a thought, not for sure. One thing Ford has always been good at is making something that works for the application it was intended, they dont just make one-fit-all, like Generic, I mean General Motors.
Yeah, mine fits in the stock location so I'm sure it is original (truck has 21,000 miles) I will probably just go with the stock replacement because I'm pretty good when it comes to proventitive maintenance.
Old Nov 2, 2005 | 07:55 PM
bwkelley76's Avatar
Good PLan, I'd rather replace my filter every 15k miles (twice as often as the book says)with the right one, than to jeopardize the integrity of the fuel system.... unless someone has proof that the bigger filter flows as well or better??
Old Nov 3, 2005 | 10:08 PM
emig5m's Avatar
Can someone post a pic of where the pressure release valve is located? I wanna change my filter saturday morning.
Old Nov 3, 2005 | 10:27 PM
gbgary's Avatar
it's on the fuel rail. black plastic screw-on cap, schraider (sp) valve. you don't really need to mess with it though. just let the truck sit for a while and it'll be ok. did mine the other night after it sat for four hours (i opened the gas cap too just before i did it. don't know if that mattered or not.). you could do it first-thing saturday morning, after it sits overnight, before you go anywhere.
