Need advice on launch with 2400 Stall Converter?
Scenario:
With 2400 stall converter, traction is no issue with slicks… is it better to stall to like 2300-2400 and launch or launch from dead idle to get best 60' times?
With my 2400 stall I launch at about 1600, but I have driven Fomocofans truck who also has a 2400 stall and his truck likes to launch at about 1800 rpms
I am installing a new about 2000-2100 stall converter tuesday so I will have to relearn my launch
George which slicks are you running?????
Can anyone explain the sciance behind the stall converter and how you can benefit from it?
Originally Posted by LightningToGo
RPM's?
Why have a 2400 stall if you'll luanching @ 1800?
I launch between 1600-1800 with a PI converter. My best 60's have come from that method. I've tried flashing it from an idle and running it all the way up to 2100-2200 but it's always inconsistent. Just play around different techniques. Everyone's truck is going to react differently so just find out what your truck likes.
Originally Posted by mhays26
I have gotten my best times stalling up as high as it goes without breaking the lights. Just try different rpms and compare your 60ft times
My best 60ft (1.65) came from an 1900-2000rpm launch (slicks would turn over if given more)
Rich
