need help (fuel prob)
Old Oct 22, 2005 | 05:30 PM
cinderss's Avatar
Well I went to the track last night and made three passes.
The first was a complete pass the next two had problems. I would make it 3/4 down the track and it would just stop pulling just sputtered out. After my last pass I pulled the slicks off to go home and trouble shoot..... But the truck didnt start now.
It was actually having a some starting issues earlier that day but I dint think much of it.
what I know:
Can't hear fuel pumps
fscs is not tripped
shrader valve has no pressure
Fp relay clicks with ignition switch
no blown fuses
Could it be the hi/lo relay or are my pumps shot??
Any help would be greatly apprectiated.
Old Oct 22, 2005 | 05:38 PM
Red_02_L's Avatar
Casey02L Might be able to help.... Paging Casey!!
Old Oct 22, 2005 | 07:22 PM
Silver-Bolt's Avatar
Might have lost the pick up on the fuel pump. Common problem on the earlier trucks. Fix involves dropping the tank. Before that check all fuses and relays. Then check voltage at the pump.
Old Oct 22, 2005 | 08:50 PM
cinderss's Avatar
I'm going to pull the bed tomorrow and check the pump and voltage.
I have searched the boards and found similar problems but no conclusions.
I'll post what I find. Keepem comming guys every idea helps.
Thanks again for the responses.
Old Oct 23, 2005 | 01:58 PM
cinderss's Avatar
Fixed!!
Turned out my CruiseControl recall had dripped brake fluid on my two relays (fuel pump hi/lo...and the other). Well the other was shorted.
The thing is I fixed the recal four months ago. Oh well I'm rolling again!!
Oh and in case your wondering how it dripped on the relay block. It was dangling around in the engine because I forgot to place it back on the metal tab.
Old Oct 23, 2005 | 02:10 PM
Rob_02Lightning's Avatar
WOW never would have guessed that one ?
Nice find Glad all is back to normal
