Ran the Lightning at the track last night...
Old Oct 20, 2005 | 10:30 AM
bluevenom867's Avatar
First time for me too
Black 99' Lightning
mods:C&L MAF with K&N filter,Bassani cat-back,Superchips MAX micro tuner on performance tune with stock shift pressure,and I did the "boost bypass".
I cant get a good image with my scaner,so Ill have to type them out.It was at Sunshine Dragstrip (1/8 mile).
1st run (ever):
R/T .668 (on a .500 tree)
60' 2.095
330' 5.952
1/8 9.075
mph 79.14
2nd run:
R/T .712
60' 2.087
330' 5.945
1/8' 9.078
mph 78.96
3rd run:
R/T .714
60' 2.070
330' 5.946
1/8 9.089
mph 78.65
It has the stock type Goodyear tires on it,and it was hot out.I also had my dad in the passenger seat,so 200+ extra pound didnt help either .
Basicly,I want to work on my R/T and see if I can get the e.t. lower.
But not to bad for first time,huh?
Old Oct 20, 2005 | 10:36 AM
netoje's Avatar
Your reaction time shouldn't have anything to do with your E.T. Most people will tell you to work on your 60' times I believe 1.8xxx, maybe lower, on F1s is possible. Also if you want a best you should try running alone with a little less weight. Other than that, Good Run!
Old Oct 20, 2005 | 10:42 AM
Yea,but it sure is nice to tree the other person
My truck is supposed to have the 3.55 gears and I dont have any traction mods.
The next mods I was looking to do was a 4.10 gear and drag radials and slapper bars.
Old Oct 20, 2005 | 11:52 AM
wydopnthrtl's Avatar
Not to bad considering the heat and weight.
I would suggest some long tube traction bars instead of the slappr bars.
And btw: If you only running at a 1/8th mile track I too would go for a steep set of gears.
Rich
Old Oct 20, 2005 | 12:01 PM
svtandy's Avatar
Rich
I second the long bars, also what could be looked at instead of gears is a set of 26" slicks. heck get both! 4.11's with 26" tires that's like what, 4.5X gears. that'll launch like a beast out of the hole!
Old Oct 20, 2005 | 12:32 PM
Yea,but I will be DD this truck to remember,so I think the 4.10 would be enough.
And I dont know about the slicks,can you get them to fit the stock lightning wheel,I think its a 18"?
I was thinking about Nitto's or BFG drag radials,what about them?
Also,do you think doing any kinda burn ou would help?
All thous runs I just gave it a quike dry hop.
As for launching,first run I just mashed the gas,the others I foot breaked it a little.
Old Oct 20, 2005 | 01:23 PM
1flightmedic's Avatar
Good luck on the DR's
I have Nitto's on the stock rims. They are lower profile than stock so they look smaller. I have an extra set of stock rims and I swap the rear to the Nitto's before I go to the track or if we are leaving out for some street racing. As for slicks, your best bet is to get 16" rims and mount a set of slicks on them the taller slick on a smaller wheel will not change the way your truck sits and will make a huge difference in you ET. My quick ET on DR's is 8.04 and heres a link of a run against a cobra on Nitrous at a recent street car shoot out.
https://www.f150online.com/forums/li...FB53C&kw=5&p=0
