smoke on startup
Old Oct 12, 2005 | 07:51 PM
meansvt00's Avatar
smoke on startup
Hey guys i have a little question for you. My truck has been smoking on start-up but only after it sits for a day or so. i have a little over 2000 miles on it and its a built short block and patriot heads. i don't know how normal this is and it seems to consume a little oil not much it was a quart low on the oil change and is now about a half quart low. do you think this is normal and just because of break-in. that's what i am hoping for. thanks for the info guys
Old Oct 12, 2005 | 07:56 PM
svt450r's Avatar
Do you have stock pcv system?
Old Oct 12, 2005 | 09:05 PM
JimIII@jdm's Avatar
Former Sponsor
This doesnt sound like the good begining to a new motors life, Incorrectly installed or bad Piston rings and valve guides usually cause these sort of problems. The patriot heads, did they come with bronze valve guides?
JimIII
Old Oct 13, 2005 | 05:59 PM
meansvt00's Avatar
no im running the L&S Oil Separator on my last motor and now this one.
Old Oct 13, 2005 | 06:01 PM
meansvt00's Avatar
JimIII
yeah i was leaning toward a leaking valve guide or seal but i hoped it wasnt. i call them and they said it has the bronze valve guides do you think this is a problem god damn i dont want to have to pull this motor out again
Victor
Old Oct 13, 2005 | 08:24 PM
JimIII@jdm's Avatar
Former Sponsor
Victor
Call me at the shop tommorow.....
JimIII
Old Oct 13, 2005 | 10:51 PM
Blown347Hatch's Avatar
If it's only upon start up, generally it's the valve stems/guides/seals problem. If you have worries, just do a compression & leak down test.
Old Oct 14, 2005 | 07:52 PM
fastdailydriver's Avatar
i have a built long block with patriot heads, after the first 500mi one quart low. changed the oil, maybe put another 300 mi on it driving local mostly hard, and now im a about a half quart low. dont notice any smoke on start up thats not normal. its runing great so far. dont know if i should be conserned yet? if its burning oil that would be blue smoke? on normal start up i see condensation smoke like white then it goes away.
Old Oct 21, 2005 | 02:25 PM
meansvt00's Avatar
you would see it. when it starts it puffs a nice cloud and then nothing. i just away for a week and just started it and there was that puff again
Old Nov 12, 2005 | 10:28 PM
jeraa2t's Avatar
Same here for stock 5.4L 2V
After about 15K miles using MC 5w-20 and motorcraft filters, I now get a puff of
light blue smoke in the morning. Oil analysis shows elevated levels..
This design issue ? on '03 Expy.
Tnx JR
Old Dec 8, 2007 | 02:22 PM
4rocks's Avatar
mustang
hey meansvt00 did you bid on a mustang on ebay last week? if so i need you to contact the seller.....
Old Dec 13, 2007 | 06:33 PM
meansvt00's Avatar
im sure i did what was the item#
