Vinnie dont give the whipple back...Part 2
We decided to step it up 2lbs at a time. This is a comparrison dyno from 18lbs to 20lbs on the Whipple. We put the 2.8 upper on and put a smaller lower on. The next dyno will be with the 8lb lower back on which our 8lb is 9.75. That should yeild 22lbs.
The 2nd graph here has a correction factor, when we ran it at 18lbs the weather was alot better so the numbers could be higher. We will be posting a video that we took at 20lbs. We will be posting that with the next video for 22lbs!
I don't think Vinnie owns it unless he bought it. Not that the spray should hurt the charger. Now from doing the math it would seem that 1 PSI additional yields 12 HP and 24.905 Torque. Definitely a lot of torque. Predictions, or rather estimations for next dyno should be around 685.53 HP and 780.55 Torque @ 22 pounds of boost. Let's see some IAT2 Temps.
Originally Posted by NCsvt2003L
I don't think Vinnie owns it unless he bought it. Not that the spray should hurt the charger. Now from doing the math it would seem that 1 PSI additional yields 12 HP and 24.905 Torque. Definitely a lot of torque. Predictions, or rather estimations for next dyno should be around 685.53 HP and 730.74 Torque @ 22 pounds of boost. Let's see some IAT2 Temps.
Throwin a lot of torque at that motor
yeah
Yeah, they do have WAY too much fun down there. But i've seen them working their asses off too!!!! Gotta pay to play.........hehehe
