Trans temp sender location
Old Sep 23, 2005 | 07:57 PM
LightningTuner's Avatar
Question Trans temp sender location
Anyone installed a trans temp gauge? I have to put one in a diesel F250 with the same 4R100 trans as the Lightning. I'm not keen on tapping the pan for it, and I noticed a small pipe plug on the driver's side, right in front of the linkage bracket. The temp sender fits perfect in there, but I'm not 100 sure that's a good spot. Anyone done this?
Old Sep 23, 2005 | 08:26 PM
01 XLT Sport's Avatar
I have and from all the other reading I have done that is the perfered location. I can say the temperature is accurate within 5 degrees. I have data logged and the computer temperature reads within a few degrees of the Autometer temperature gauge.
Old Sep 23, 2005 | 08:28 PM
wkuper11's Avatar
Sal, I believe that is the spot that Greg Evans used to reccommend.
Old Sep 23, 2005 | 08:30 PM
meansvt00's Avatar
Frequently Asked Questions
by Gregg Evens
Where can I install my fluid temperature gauge?
On the passenger side of the transmission, there is a test pressure port with a pipe plug in it, you can remove this pipe plug and install your temperature or pressure sending unit here. Most gauges are already the correct size or come with adapters to fit it.
thats what i found sounds like the same spot you said Sal
Victor
Old Sep 23, 2005 | 08:41 PM
Awesome, thanks guys! I checked the fluid schematic for the trans and also found that it was the high pressure test port, and figured that's gotta be a good place .
Old Sep 24, 2005 | 03:51 AM
WaveBlaster785's Avatar
That's where mine is.
Autometer tells you you don't have to ground it either, but if you don't the guage will just creep its way to the max temp.
Old Sep 24, 2005 | 08:08 AM
Fast Gator's Avatar
by Gregg Evens
Victor
Nobody else notice this?
Old Sep 24, 2005 | 09:12 AM
Casey02L's Avatar
Mine is on the driver side as they had mentioned; seems to be working perfect.
Old Sep 24, 2005 | 09:13 AM
SMOKINTRUCK#1's Avatar
umm! I read in Greggs earlier post to use pipe thread-tape on the threads of port,then on another posts he states not to use it, can contaminate tranny fluid what should be used there? joint compound ,tape etc ? Thanx!
Old Sep 24, 2005 | 02:06 PM
Mickey_shouse's Avatar
I have mine installed on the drivers side. Asked the one i ordered it from where to put it and they told me that exact place. Also did a few searches to just make sure.
Old Sep 25, 2005 | 10:45 AM
BUMP!
Old Sep 25, 2005 | 10:53 AM
KIRST8404's Avatar
Just so everyone is clear......
I didnt use anything on my threads and no leaks. It is a pipe thread so it tapers down at the end.
Old Sep 25, 2005 | 07:26 PM
Factory_Tech's Avatar
BUMP!
Oops, don't use tape, that was just a brain fart, as was the passenger side. It is on the drivers side, as shown in the abovve diagram.
G
Old Sep 26, 2005 | 03:11 PM
02Thunder's Avatar
Thanks for that tip! My gauge has been a PITA, and now I know exactly why.
Joe
