Help me identify the sound
Old Sep 17, 2005 | 11:00 PM
ccattie's Avatar
Ok I'm going to need all the scooby doo's out there for this. I've got a weird noise and I only seem to hear it on warmer days. When its cool, I don't hear it. If its over 80 it comes back. It sounds almost like a couple of dimes jingling around in an old glass jar. I hear it when I get to just about 0 on the boost gauge and up. I never hear it at the lower RPMs it seems. It sounds like its more on the drivers side that anything and I can't tell if its under the dash or in the engine bay. This isn't pinging is it?
-c
Old Sep 18, 2005 | 03:03 AM
Spanky99L's Avatar
def sounds like your pinging. i would see if you got a bad batch of gas or something
Will
Old Sep 18, 2005 | 09:11 AM
Rob_02Lightning's Avatar
WHERE'S MY SCOOBY SNACK
If it is pinging (Detonation), what makes it weird is, on a COLD day the puter will add timing, BUT on a hot day it'll pull timing, (hence pinging only when Hot makes no sence if it's timing related ???)
Can you tell us your mods, are you running a Chip / Program ?
Cavatation is a very common noise on a Lighting that many have a hard time identifying, but that is usually heard only on idle and if you simply raise the RPM it'll go away, so I dont think thats it ???
Originally Posted by ccattie
It sounds almost like a couple of dimes jingling around in an old glass jar. -c
ARE YOU POSITIVE it doesnt sound like a couple of dimes jingling around in a NEW glass jar ???
WHAT "OCTANE" "AND BRAND" of Fuel are you using ?
Old Sep 18, 2005 | 02:02 PM
ccattie's Avatar
It could be a new jar. I just thought of the old mason jars in the basement I use Sunoco 94 Ultra or Shell 93 V*power almost all the time. It's been a while now that I've been hearing it.
-c
Old Oct 5, 2005 | 10:11 PM
Unchained's Avatar
I seem to have developed a similar problem after installing a 4# lower pulley on my 2001 Lightning. I was getting 10# with the stock pulley so I am getting about 14# with the pulley. Its difficult to describe the noise but dimes in a glass jar seems about as good a discription as anything else. I hear the noise on warm days 90+ degrees at higher RPMs (over 2200RPM). At WOT, when I hear the noise I also feel a loss of power. I also get a sputtering when it is warm.
A few days after installing the pulley I was driving with cruise control set to about 70MPH, and as I climbed a small hill my RPMs and speed kept steady but my boost slowly climbed from vacuum to about 9# when I pulled off the road. The boost was climbing even after I got over the hill.
The next day a vacuum hose got disconnected and I lost all boost. I got this fixed and I have my boost back but it still makes the noise.
I can't tell where the noise is comming from.
The only mods I have are a k&n filter, 4# lower, and the Predator's performance pulley tune installed. I tried going back to the factory tune, and the truck ran like crap and backfired constantly.
Old Oct 5, 2005 | 10:49 PM
trublu gen2's Avatar
By the description, it sounds like detonation. Get a custom dyno tune by a reputable tuner. Otherwise, you may be in the market for a new engine. If you hear that noise, DO NOT stay in the throttle, let off. You need to have this problem taken care of asap.
Old Oct 9, 2005 | 11:26 PM
LTNDave's Avatar
sound like detonation to me as well
