?? - Nitrous Question - Predator Tune -
Old Sep 6, 2005 | 04:13 AM
Lightning1983's Avatar
Ok i have a stock 01 lightning with just a predator tune if i was to get a nitrous kit a wet kit how much would i be able to spray and be pretty safe with or could i spray a 100 shot and still run a 4lb pulley with it?
Old Sep 6, 2005 | 10:00 AM
Silver-Bolt's Avatar
Safe is a relative term. You would be safe however your motor would not be. If you plan to spray you had better get with a tuner that can hook you up with a juice program. I assume you are on a stock motor? 4LB + 100shot may work once or twice but it will fail.
Old Sep 6, 2005 | 11:53 AM
probie's Avatar
I'd definately recommend getting the truck tuned and dyno'd before you start spraying at the track or on the street. I run a 50 shot & 6# pully with JLPs nitrous tune a/f is perfect.
