Any EGR Experts ?
Old Sep 6, 2005 | 11:40 PM
Suavy's Avatar
Originally Posted by airtroop01
I've been doing the same checks on my EGR too.
Under boost the line to the diaphram sometimes blows off.
So far I'm the only one I've heard that happening to.
I've checked the lines and all looked good and nothing connected to
the wrong spot.
I was going to replace the diaphram. I'm guessing if it is stuck open a little, it could be allowing exhaust gas in all the time and it could be allowing boost out the manifold.
I do have a EGR delete, but wanted to keep the system intact.
Good luck Rob! I need some luck too.
What you are seeing is most likely from back pressure. My tubes kept poping off also it stopped when I took the cats off. Cats were almost plugged shut!
Peace,
Suavy
