Help!
Old Sep 2, 2005 | 06:44 PM
Brutis99SVT's Avatar
Help!
On my way to work yesterday I noticed a small problem with my 99. The drivers side window doesnt work!! I was wondering if anyone has had this problem before and what they had to do to fix it. I can hear the motor clicking but still no movement. I called the local Ford dealer and they said it was a $300 fix!! I hope thats not true. If anyone has any suggestion please post.
Thanks.
Brutis
Old Sep 2, 2005 | 09:35 PM
Silver-Bolt's Avatar
Just happened on my Ranger a couple of weeks ago. Put the window down and it would not go back up. I could hear the solenoid click but nothing. Power window motor went teats-up. Fortunately it's under warranty. If you are out of warranty hit ebay. Any F150/Expedition power window motor will work. Just make sure it is from the same door as your bad one. IE driver's side.
Old Sep 2, 2005 | 11:52 PM
IBR8K4VETTS's Avatar
Try hitting the door panel with a rubber mallet and holding the window switch at the same time.
Mike
Old Sep 3, 2005 | 09:15 AM
usaf_eagle's Avatar
unfortunately its most likely the window regulator and those suckers are not cheap..
Old Sep 3, 2005 | 11:46 AM
Thanks for the info, I was hoping it was just the gears, but it sound like Silver-Bolts problem. I guess I will be searching on ebay this weekend . I tried hitting (out of anger ) but that didnt work.
