Alternative Intercooler Fluid Cooling
Old Sep 1, 2005 | 02:46 PM
TampaBlack99's Avatar
Wonder if it actually cools the liquid? Would be easy to install ice and keep the water cold.
http://www.haydenauto.com/newproducts.htm
Old Sep 1, 2005 | 02:51 PM
halcyon's Avatar
huh, is that like what the WRX STI has?
I test drove one and there was a button that read something like I/C spray or I/C water.
Old Sep 1, 2005 | 03:32 PM
Master Of Pain's Avatar
The I/C for the WRX is Air/Air. Watermisting will have a much better effect for that system than our Water/Air.
Old Sep 1, 2005 | 06:18 PM
rickgig's Avatar
It's a cool idea (no pun intended) but you won't be racing at a sanctioned track anywhere. Water and track doesn't mix very well.
Old Sep 2, 2005 | 10:12 AM
wydopnthrtl's Avatar
Spraying down the radiator right after a pass is an age old trick for southern boys. Up here in the north I've *never* seen anybody do it.
(yes it's a effective way to transfer heat)
Rich
Old Sep 2, 2005 | 12:44 PM
MGDfan's Avatar
Hi.
The process this is utilizing is called the "Latent Heat of Evaporation".
Explained here:
http://daphne.palomar.edu/jthorngren/latent.htm
This will work no matter what intercooler/aftercooler/radiator or other heat exchanger is being used.
The actual temp of the water in the reservoir is not very important - the change from liquid to vapour will absorb approx 600 calories per gram of water atually evaporated. That's quite a bit, actually.
The misting maximizes the surface area of the water as it comes into contract with the surface to be cooled ( in your case, the inter/aftercooler).
Also works at the beach - see all those chicks with their little spray bottles? I know, I know...what spray bottles?
Ain't physics fun? Class dismissed.
Cheers
Grog
Old Sep 2, 2005 | 03:51 PM
Black02SVTL's Avatar
How much? I wouldnt mind trying it out.
Old Sep 2, 2005 | 05:28 PM
If it's too much, I already have the info to build my own.
