How should I get this thing off ??
Old Aug 30, 2005 | 07:56 PM
Blown5Pnt4's Avatar
O.k. guys, I'm looking to up my pulley. When I bought my truck it already had an original JDM Caged Solid 1 Piece 2# Pulley on it. In my pulley searches I read that alot of people have had problems getting these style pulleys off. Now this pulley has been on my L I'd say at least 15k miles, if not more. Noone really stated how they finally got them off, but I'm worried about breaking something. Whats the best way for me to get this thing off without any damage to the truck ?? Thanks....
Old Aug 30, 2005 | 10:12 PM
Robert Francis's Avatar
It's either on here or on the NLOC Fourm that there are some good posts on what some guys went through in removing the older JDM caged style pullys - photos and all. I recall seeing them.
Old Aug 30, 2005 | 10:52 PM
svt_2004's Avatar
do you want to sell the pulley?
Old Aug 30, 2005 | 10:55 PM
Blown5Pnt4's Avatar
lol if I can get it off, without breaking it yeah I will be.....
Old Aug 31, 2005 | 08:35 AM
Dan SS2471's Avatar
Do yourself a big favor and don't even try to use the nut to get it off. You're going to waste your time, strip the nut and ruin the spindle anyway. So I suggest you cut to the chase and:
1) Get a piece a steel fence pipe and cut off about a 3 1/2 ft. section.
2) With the front end jacked up as high as you can (with front tires removed), put a large pipe wrench on the spindle (not the nut) and position it at about 5 o'clock. You probably will, but make sure you have someone helping you. Makes it alot easier.
3) Have the other person slide the pipe over the pipewrench while you position yourself so that you can push it from the driver's side with BOTH of your legs. I laid on my side and had my torso wedged against my garage wall.
4) Push as m-fing hard as you can and it should break loose. Don't forget to loosen the cage too.
5) Be prepared to think someone discharged a shotgun when it breaks loose. You'll more than likely think either you or your assistant was hit because the pipe and pipewrench are going to go flying.
EDIT -
Here's what it's going to look like no matter what you do:
Hope this helps.
Dan
Old Aug 31, 2005 | 08:42 AM
halflife's Avatar
Originally Posted by Blown5Pnt4
O.k. Whats the best way for me to get this thing off without any damage to the truck ?? Thanks....
simple answer: let Sal do it!
Old Aug 31, 2005 | 10:34 AM
JayL's Avatar
Get the tools out, get under there and just try it. Some have had problems, and some have not. Best of luck to you....
Old Aug 31, 2005 | 11:15 AM
soap's Avatar
Am I missing something
If you just want to add more boost changing the ring takes all of 15 minutes.......why does he have to remove the cage?
--Joe
Old Aug 31, 2005 | 11:17 AM
LightningTuner's Avatar
--Joe
Josh has the FIRST design of the caged JDM pulley. It's not interchangable, and it doesn't have the spindle that sticks out.
Old Aug 31, 2005 | 01:12 PM
Odin's Wrath's Avatar
If you want to resell it, break out the torch. It's the only guaranteed way to get it off without damaging it beyond usability.
Old Aug 31, 2005 | 01:26 PM
SILVER2000SVT's Avatar
+1
Get the torch in behind the pulley to heat the adapter. Apply just a little heat, Be quick so you don't let the heat soak into the spindle.
Use a good closed end wrench and pipe on the small hex not a socket wrench. This will keep you from applying any side load which will make the socket slip off and twist the hex.
Old Aug 31, 2005 | 01:30 PM
soap's Avatar
Didn't see that......thanks Sal.
--Joe
Old Aug 31, 2005 | 02:15 PM
Blown5Pnt4's Avatar
oh jeez this dont sound fun.....My biggest concern is stripping the thing off...Hey Sal, you sure you dont wanna attempt this for me ??
Old Aug 31, 2005 | 03:39 PM
Rob_02Lightning's Avatar
I bet he will
FOR 1 MILLLLLLLLLLLLLLLLLLLLLLLLLLLLION DOLLARS
