question for mp owners
Old Aug 27, 2005 | 10:28 PM
svtsilverback's Avatar
SAUVY what mods do you have? also what is the spring upgrade about? sorry a rookie. thanks everyone and keep info coming
Old Aug 29, 2005 | 09:05 PM
Suavy's Avatar
Mods...
Engine – 5.4 L Cast Iron Block
· Bore - .02" over
· Rings Plasma Moley
· Cylinders honed using deck plates
· Line bored Crank bore
· Crank & rotating system balanced & blue printed
Heads – Stock heads with the following mods
· 1mm oversized valves intake & exhaust
· Cams Crower stage 3 with .601" lift
· Stage 3 springs set at 118 ft lb of seat pres.
· Retainers titanium
· Heavily ported intake and exhaust
Intake – Stock with the following mods
· Matched ported to heads
Supercharger – Magnum Powers
· 2.69 Lb pulley
· Snout turned down to run the 2.69 lb pulley
Fuel System – Stock Fuel Rail
· 55lb hr injectors MSD
· Duel 255 fuel pumps
· ½" steel braided fuel lines
· Nitrous ported manifold
Intake air – Cold air set up
· Johnny Lightning Performance Ram Air down pipe
· JDM engineering cone filter set
· Up graded to 2001 factory MAF meter
· Excalibur MAF extender
Cooling system – Stock
· Water pump – stock
· Thermostat – stock
· Hoses – stock
· Fan – stock
· Inner cooler – stock with home made chiller box system
Transmission – Factory Tech Monster Box
· 2600 RPM stall
· Torque converter – billet
Rear end – stock
· Rebuilding not yet complete
· Up graded to carbon fiber clutch plates
Suspension – Up graded
· Shocks – QA-1 adjustable (Rear)
· Rear lowered 3"
· Front – stock shock
· Springs – stock front and back
Traction – Up graded
· Johnny Lightning Performance lift bars
Exhaust – Up graded
· Magnaflow cat back
· Magnaflow high flow cats
· Headers – Long tube - Lightning Force Performance
Computer – Stock PCM
· SCT program with 2 programs (Billet Speed Performance)
Tires – 20" American Racing Prisms (Daily Driving)
· Racing – Front 16" X 8" Good Year Eagle GT's on Eagle alloy rims
· Racing – Rear 16" X 10" Mickey Thomson ET Streets & Hosier ET Drags on Eagle Alloy rims
Valve springs are set at 118 lb of seat presure so they don't lift with high boost.
Peace,
Suavy
Old Aug 29, 2005 | 09:09 PM
Fast Gator's Avatar
Originally Posted by Suavy
Mods...
· Bore - .02" over
· 2.69 Lb pulley
· Hoses – stock
· Fan – stock
· 2600 RPM stall
Rear end – stock
· Rear lowered 3"
Exhaust – Up graded
Peace,
Suavy
Thats all?
Old Aug 29, 2005 | 09:11 PM
Suavy's Avatar
Originally Posted by Fast Gator
Thats all?
Heck, I have to have that and the kitchen sink to keep up with you your royal Gatorness!
Peace,
Suavy
Old Aug 29, 2005 | 09:14 PM
Fast Gator's Avatar
Peace,
Suavy
all shucks........
just remember my motto
Faster Than Rob02
Old Aug 29, 2005 | 09:16 PM
Suavy's Avatar
all shucks........
Faster Than Rob02
Hey check out Lightrodder I made a post I used your name in it!
it's called customer feed back by Big Stew
Peace,
Suavy
Old Aug 29, 2005 | 10:12 PM
Blown347Hatch's Avatar
That's a baaaad mutherf"er!!!
Mods...
· Bore - .02" over
· 2.69 Lb pulley
· Hoses – stock
· Fan – stock
· 2600 RPM stall
Rear end – stock
· Rear lowered 3"
Exhaust – Up graded
Peace,
Suavy
Old Aug 30, 2005 | 08:01 PM
Suavy's Avatar
Thank's just a little something I threw together!
Peace,
Suavy
