Overfilled transmission
Old Aug 24, 2005 | 11:18 PM
FunFord's Avatar
Registered User
I check my trans fluid level today and noticed it was overfilled, should I drain some out or will it run out the overflow? Thanks!
Old Aug 24, 2005 | 11:41 PM
99 SVT Bolt's Avatar
Drain it out IMO. Is there a overflow?
Old Aug 25, 2005 | 12:07 AM
Tim Skelton's Avatar
There is an overflow, alright.
One time after hot lapping an autocross course for about a half hour (!), I had tranny fluid puking everywhere.
Ford service guy who was there said just keep kicking its *** and the tranny would decide the appropriate fluid level for me.
Old Aug 25, 2005 | 11:46 AM
FrankLee's Avatar
How did it get overfilled?
Old Aug 25, 2005 | 01:28 PM
I put too much fluid in.
When subjected to intense conditions, our transmissions like to be slightly underfilled. When I filled the transmission with fluid, I was unaware of this.
Same thing with the rear end. Expect it to puke fluid if you drive it hard. I installed a pint catch can/breather on the end of the hose.
SVT did its best to deliver a performance vehicle that could handle aggressive driving (for longer than 1320 feet). But much of the stuff that they started with just was not designed for it. So there are limitations that you have to learn to work around.
Old Aug 25, 2005 | 03:14 PM
Rob_02Lightning's Avatar
I still got the wrong Trans Fluid in mine
And you all said it would ruin my transmission,
HA
Old Aug 25, 2005 | 03:26 PM
Scott Dunn's Avatar
An overfilled trans will aerate the fluid and overheat it. This can kill a transmission.
Scott
Old Aug 25, 2005 | 03:55 PM
Ct.TOPGUN's Avatar
For Rob, I hope you change that fluid out rather than risk damage. I know you dont have many miles on the truck and perhaps that is saving you thus far.
Old Aug 25, 2005 | 04:51 PM
HA
Ah ha. I think we know why you can't lay down any numbers from your new setup.
The tranny fluid has turned to peanut butter and is now the only thing keeping the fragged internals together.
Old Aug 25, 2005 | 06:38 PM
FunFord's Avatar
Registered User
So should I leave it in and wait for it overflow, or should I drain it?
Old Aug 25, 2005 | 11:59 PM
Scott Dunn's Avatar
Drain it.
Old Aug 26, 2005 | 01:53 AM
You have a Moroso pan with a drain plug. Why not drain it?
Old Aug 26, 2005 | 02:14 PM
Blown347Hatch's Avatar
Scott
That applies to engines because the crank whips and aerates the oil. I don't believe a tranny cares, except that the fluid expands due to heat and then goes out the overflow.
