180 thermostat
Old Oct 21, 1999 | 09:30 PM
gp's Avatar
gp
Post 180 thermostat
has any one tryed changing to a 180 thermostat to maybe lower under hood temperture?if so, will it affect the computer .ive heard it may make the motor run richer.could be a cheap improvement.
Old Oct 21, 1999 | 10:25 PM
William Mallo's Avatar
Post
The computer will adjust it self . But it is an OBDII system . May cause the check engine light to come on . May set a code for not eaching proper temp on drive cycle. OBDII has drive cycles at it test it's systems for problems . I work on cars for a living and have seen ford,gm,toyota,honda, and nissans . Set code do to bad tstat. Let us no if does cause light to come on .Maybe 180f tstat is close enough that want be a problem.
99.5 Black Lighting
cd,tow pack,ford bed liner,wantto lower
