What cam set up?
Old Aug 23, 2005 | 09:42 PM
Whitelighting's Avatar
What cam set up?
Gonna be getting the stage 3 patriot heads what cams do you all recommend ,I read stage 2 cams give you low end TQ ,any ways i so new at all this just want to do this right the 1st time.
Thanks Bob
Old Aug 23, 2005 | 10:24 PM
BigBobsL's Avatar
Thanks Bob
I beleve you will find Patriot only offers one cam choice, the equivalent of a Comp Stage II. Their Stage II vs Stage III cams differentiates between stock diameter valves and 1 mm larger valves. Their price on cams (when purchased with heads) is hard to beat!
Old Aug 23, 2005 | 10:37 PM
evo's Avatar
evo
Do you need to upgrade the torque converter to a higher stall?
Old Aug 24, 2005 | 12:04 AM
Spanky99L's Avatar
patriot cams are VERY mild. not even a stage 2 cam. for they price they are great but if you want to make big power go with a crower or comp
Will
Old Aug 24, 2005 | 03:40 PM
LightningToGo's Avatar
I'm very happy with my Comp Stage II cams! I have heads ported and polished by Patriot.
Old Aug 24, 2005 | 08:56 PM
Will
What stage do you have in the crower?
THKS Bob
Old Aug 24, 2005 | 09:30 PM
BigBobsL's Avatar
Will
If you compare cam cards, you will find Patriots essentially identical to Comp Stage II's. I have degreed them both in.
You do not have to have a converter with Stage II cams since idle will still be low enough (700-850 rpm), but truck will of course run quicker with one, same as with stock cams. All the trucks with cams I know already had convertors, however a friend will soon have a built motor runng with stock convertor.
As noted in another string, I do not recommend Crower's any more since they would not replace my custom ground cam of MY specs (now listed by Crower as Stage III N/A) that was ground with 121 LSA on one cam rather than the 114 specified. Replaced it with a Crane of essentially same specs.
