I need help
Old Aug 20, 2005 | 10:41 PM
Woodys2000's Avatar
I need help
Hey guys I ran my NOS system today and some how I have screwed up. The truck will not start. When I turn the key nothing. Only a blinking "Theft" light. WTF do I do now?
Old Aug 20, 2005 | 11:24 PM
Spanky99L's Avatar
something in the PATS system is screwed up. Check to make sure the battery is connected tight. also your chip is completely on and the connector to your pcm has not come loose
Will
Old Aug 21, 2005 | 12:12 AM
ShockTherapy's Avatar
Maybe a loose ground wire?
Old Aug 21, 2005 | 12:16 AM
Rob_02Lightning's Avatar
If not one of the things they're saying
Did you cut into any factory wires ? If you did, what exact one ?
Incoming Power feeding the System + Arming Switch, Where's that coming from ? Is there Micro Switch, or Elec TPS Switch ? If there's a TPS switch, what wire did you cut into for that ?
Old Aug 21, 2005 | 12:33 AM
Woodys2000's Avatar
The TPS is ran from a fuse block I bought and the power from that is ran from my battery. I didn't cut and factroy wires. I ran all new ones for the system, IE from thew battery to the fuse block, to the switch to the accesory. I hooked up the blanket, seleniods, purge, and line lock.
Old Aug 21, 2005 | 09:40 AM
Woodys2000's Avatar
Could it be because I took the ground off the ProLock? I put it back but for about 30 minutes while I was getting the wires strait it was off. And for those of you who don't know the "ProLock is some starter disable that was on my truck when I bought it.
Old Aug 22, 2005 | 10:38 PM
Woodys2000's Avatar
Ok guys I got the new PCM and still nothing but the number 2 relay in the drivers compartment keeps getting real hot when I try to start the truck. It won't do anything. Any help guys?
