New Item!!!JDM BIG POWER FUEL SYSTEM
Old Dec 7, 2005 | 07:33 PM
  #46
Whitelighting's Avatar
Originally Posted by Whitelighting
Suavy what fuel rail are you usin getting ready to put uilt motor in and up grade fuel system ,already have 60lbs and 255s in guess lines and fuel filter and rails are next..thanks for any help O do you have the spacer mod on ur truck the 1 that goes under the sc?
Thks again Bob
TTT
Old Dec 7, 2005 | 11:23 PM
  #47
Casey02L's Avatar
Originally Posted by Casey02L
Aight; what's so special about the "97" rails/regulator? If you arn't going to an aftermarket adjustable regulator then why switch rails? The injector holes are the same size the fuel inlet size/pipe is the same, and the outlet is the same. The rails are the same size pipes.
Should be interesting to hear the reason
JDM closed up shop or something
Old Dec 7, 2005 | 11:40 PM
  #48
Suavy's Avatar
Thks again Bob
I am using stock but have a F-150 2004 fuel rail returnless that I am going to try to run if I stick with the 2 V set up next year.
No I do not have a spacer under my supercharger but do have the one between the upper plenum and the top of the supercharger.
Hope this helps.
Peace,
Suavy
Old Dec 13, 2005 | 12:06 AM
  #49
onebadf150's Avatar
If yall are looking for the fuel filter summit has it for $75 heres the link
http://store.summitracing.com/defaul...h.asp&N=400249
Old Dec 13, 2005 | 11:59 PM
  #50
Frank5L's Avatar
Single -6AN? Seriously? And supporting 800, SAFELY?!? WOW
Guess my new setup with twin -6 lines will be pretty good, all I am wanting to make is just something around 1200.
Old Dec 14, 2005 | 12:08 AM
  #51
LatemodelRacer2's Avatar
gotta love frank
Old Dec 14, 2005 | 12:26 AM
  #52
Casey02L's Avatar
That all pffft
j/k
