autometer phantom water temp gauge install ?
Old Aug 9, 2005 | 09:56 AM
beefcake's Avatar
going to install this gauge, does anyone know if it uses stock location? also, where is stock location?
what kind of install time?
Old Aug 9, 2005 | 11:26 AM
TampaBlack99's Avatar
Lower Driver's side on the block.
Old Aug 9, 2005 | 01:07 PM
Stl01SVT's Avatar
My electric fan sensor occupies that location. So, I drilled and tapped a hole in the thermostat housing, to install the temp gauge sensor.
Old Aug 9, 2005 | 02:03 PM
All you really needed to do was run another electrical line to the sensor you install in the block for the fan. They should be the same.
Old Aug 9, 2005 | 02:15 PM
LightninMike's Avatar
they are the same??? now this might get me smacked but i called JDM for a replacement and they said they were not the same
Old Sep 18, 2005 | 06:00 PM
beefcake's Avatar
okay, next question, since it really doesn't explain anything in the directions, i am assuming you take the smaller of the 2 plugs with the holes in them, and then put the little thing that screws into it, in it, and then pull the allen plug and screw that in
correct?
Old Sep 19, 2005 | 04:34 AM
i didnt understand a damn thing you just said
is it electrical of mech?
Old Sep 20, 2005 | 09:58 AM
Spoyldrotn's Avatar
correct?
Beef,
That is correct. If I remember correctly, you use the largest adapter that comes with the sender and screw the sensor into it.......it has to be put in with a 11/16ths deep socket so that should help you figure out which adapter to use. Just make sure you are ready to go with the sensor when you remove that plug or you'll be drenched in anti-freeze. If you're fast you'll only lose a few ounces. Hope that helps. I'm assuming you are installing an electric gauge.
