Need help w/ Thumping sound
I recently had a 1/3 ground force lowering kit added to my truck. Now when I hit a heavy bump I hear a thump like something is hitting something. Please assist. What is it and how do I fix it.
you are prolly bottoming out.
Check out your rear bump stops. Try cutting them or getting shorter bumpstocks. Usually it takes a 4-5" drop to bottom out bad.
You can also C-notch ur frame to clear the stops...
Go buy some carpenter's chalk. Sprinkle it on one surface of any suspected contact points. Find a really rough road near your garage and try to force contact. Then get back underneath and see if any chalk has been transferred.
I have also used grease and masking tape with the same effect.
