Lightning Tranny (hey PFA)
Hey PFA, Sal here. I checked that part number you gave me for the 99 Lightning tranny that was put in your truck, and it is correct.....
SAL
Power Surge Performance--- Your SOURCE for SVT Lightning EFI Tuning and Performance!! <A HREF="http://members.aol.com/NLOCsvt/svt.html
" TARGET=_blank>http://members.aol.com/NLOCsvt/svt.html
</A>
SAL
</A>
Thanks Sal for the response. At least I know it should be the correct one.
PFA
'99 WHITE LIGHTNIN'
#0873
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Best ET-14.18
Superchip
PFA
'99 WHITE LIGHTNIN'
#0873
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Best ET-14.18
Superchip
Hey Sal,
Do you think the upgrade shift solenoid pack by level 10 will make a difference in my truck. By the way, If you remember my shifting question, the problem was the valvebody. The guy who rebuilt overtightened it. I put it at 80 inch pounds and it works great.
95' Vortech Supercharged White Lightning
Hey Sal,
Have you got any dyno numbers or et improvement times with your air filter assembly yet?
PFA
'99 WHITE LIGHTNIN'
#0873
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Best ET-14.18
Superchip
PFA
'99 WHITE LIGHTNIN'
#0873
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Best ET-14.18
Superchip
Hey Joe Mama, Sal here. What kind of difference are you looking for? I can pretty much do anything with my chip that any "mechanical" trans upgrade (except a convertor replacement)can offer and it will be much easier to install and is safer for the tranny.
SAL
</A>
SAL
</A>
Sal,
I did'nt know you had chips for the 95's. Will the chip work with my set-up? I have the Pro-M mass air conversion which I'm sure you know that two different computers are running the truck. One for the engine and one for the trans. All I am looking for is a substancial increase in line pressure and a little bit different shift points.
Hey Joe, Sal here. With the Pro-M set up, I can't do a chip for the Mustang computer because all I do is Lightning tuning and don't have the software for that ECU. But I can do a chip for your stock Lightning PCM which still controls the tranny, and that's what you are looking for anyway. One of the main problems with the Pro-M mass air is the poor communication between the two computers that usually results in poor tranny operation. That's why I developed the mass air conversion I sell for the early trucks. But since you already have the Pro-M, I can do the chip for the tranny stuff on yours. You should check out my web site below.
SAL
</A>
SAL
</A>
