What all is different from a 2000 Lightning & an 03'?
Old Aug 6, 2005 | 01:05 PM
LightningTuner's Avatar
Originally Posted by 01 XLT Sport
Sal,
What was revised with the piston because of the 99/00 piston slap?
Ford added a coating to the side of the pistons, to take up the "slack" of the forged pistons. I thought that was a BS idea, but it obviously worked because you never hear anyone with an 01-up complain of piston slap.
Old Aug 6, 2005 | 06:31 PM
ShaneMcKenna203's Avatar
Are the rods as strong in the 03's as the 2000's? What is it in either year that made them stronger than the 01-02's? They weren't forged, they were just a different kind or rod, or what exactly?
Old Aug 7, 2005 | 02:28 AM
rav1972's Avatar
mid to high 13's for stock
Old Aug 7, 2005 | 08:05 AM
jimkalfakis's Avatar
Hey Sal, I`m slappin` my piston right now pal. And no one is complainin` here. What ya think of that? huh?
Old Aug 7, 2005 | 08:19 AM
bglanden's Avatar
Originally Posted by jimkalfakis
Hey Sal, I`m slappin` my piston right now pal. And no one is complainin` here. What ya think of that? huh? :
Now that's Funny!!!LMAO!!
Bryan
Old Aug 7, 2005 | 12:10 PM
TrackBeast's Avatar
A few in there, I didn't even know. Sal really knows his stuff.
I also heard that some of the cooling parts on the 00 came from the HD diesel truck and didn't the rad have higher cooling efficiency.
Other than the thread on the heads issue, it really looks like the 00 is stronger built in some areas. As far as the intercooler, this is a non issue because Ford replaced all of them with the new design. For the record, 00 and 99 don't have leaky intercoolers.
TB
I'm prolly a little rusty on the subject, but here goes....
Different rims
Different headlamps, side markers, taillamps, fog lamps
Different grilles
03 has keypad entry
03 has LED 3rd brake light, 00 has bulb style
03 has more payload capacity, and is higher in the rear stock
03 has Bilstein shocks and poly snubbers
Different window/door lock switches
Different grab handles
Different stereo options
00 has 3.55s, 03 has 3.73s
00 has 80mm MAF, 03 has 90mm
03 has larger hole in inner fender for airbox
03 has 8 thread plug holes, 00 has 4 thread
03 has revised pistons for 99-00 slap issue
00 has stronger rods
03 has improved lower intake design, and improved I/C core
03 has plastic timing chain tensioners with o-ring seal, 00 has metal with machined seal
03 has stamped steel crank trigger wheel, 00 has cast
03 has full rubber brake booster line, 00 has metal line that bolts to engine bracket
03 has aluminum driveshaft, 00 has steel
03 has side marker lights built into side mirrors
00 balancer uses 3 bolt adapter for lower pulley, 03 has it cast into the balancer
That's all I can think of right now, I'm sure there's more.
Old Aug 7, 2005 | 01:08 PM
phizer350's Avatar
Not sure on the 2000's, but my 2001 had double sunvisors, the normal one with up/down and swivel movements and another little one that just went up and down. Both my 04's did not.
Old Aug 7, 2005 | 04:07 PM
TXSVTLIGHTNING's Avatar
Sal, do you have any of the 99-02 "Hard" Vac- Brake tubes that go from the plenum to the brake booster? Maybe the bolt too? Would like to swap mine out.
rickATaustinsvt.com
Double Visors are '01 only, as well as the "Oh-chit handle" up above the door on the pass. side.
