Any particular hex bit for KB pulley swap?
Going to turn up the boost a bit by swapping my 3 1/2" with a 3 1/4".
I've done some reading and found on here that the bolt is standard thread - 14mm. KB's site says 10mm. Can anyone give me a straight answer?
Also, I was planning to pick up the hex bit at Sears. Does anyone use Crafstman for this? Will I be ok with that? I don't want to strip the darn thing.
Any info is always appreciated!!
Dan
Dan
You need a 10MM allen socket. Also need a KB pulley tool to stop the blower from turning over while trying to loosen the bolt. -Mat-
EDIT: I have used both a Craftsman and a Snap-On allen socket before. No issues with either.
Originally Posted by Dan SS2471
Thanks guys. I have the removal tool, just not the socket. I'll head over to Sears at lunch and see what they have.
Dan
Dan
Originally Posted by Casey02L
Only thing I found a problem was it needs to be a fairly long allen due to the KB tool. I think I'm actually using a "Husky" from Home Depot.
Thanks again..
Dan
Well..answered my own questions by swapping the pullies. Thanks again for the info, guys. Took about 5 minutes to do the swap.
Now it's time to wait for rush hour to end and go romp it and see how much more boost, if any, it's pushing. Tough to tell around here lately it's been so friggin' Africa hot.
See ya'
Dan
See ya'
Dan
