Tips on removing starter motor........
Old Jul 29, 2005 | 03:16 AM
tallimeca's Avatar
if you have never done it before..........there is 3 bolts. We were working on a truck with headers and not only could you not see it, but after 45 minutes of the starter not coming out and us thing it was jammed, we figured there was another bolt and we couldn't see it because of the headers.
Just a fyi for anyone. I am used to the 2 bolts on my 302 and 351's........
Old Jul 29, 2005 | 08:44 AM
KB ZILLA's Avatar
Yeah, the top bolt is a B1TCH !!!
Old Jul 29, 2005 | 09:31 AM
Casey02L's Avatar
I installed mine on the built motor BEFORE the header went on.
Old Jul 29, 2005 | 12:58 PM
LightninMike's Avatar
next tip
dont drop the bolt on your face
Old Jul 29, 2005 | 01:23 PM
afchad's Avatar
Yea....mine was a PITA!!!! The top bolt was a pain. I jacked up the front...removed the fenderweld....and dropped down the header. Good luck.
Old Jul 29, 2005 | 04:18 PM
tallimeca's Avatar
yeah
well, AFTER we realized there was 3 and not 2, it wasn't bad. Just used two 6 inch extension with a 1/4 drive 13mm shallow socket. Slid the socket up on there while using the Hubble telescope to peak between the header pipes. Once on, i got a longer extension and a ratched.
F taking the header off
Old Jul 29, 2005 | 08:51 PM
lightninquick's Avatar
i wish i would have seen this post sooner
i use a very long extension with a knuckle then another extension and take the bolt out from the front of the motor
