MAF Sensor Cleaning?
Originally Posted by brain bypass
most rubbing alcahol is isopropyl, at least that i have seen. if you want ethyl alcahol look towards you local liquor store.
However, at this point, I must agree with the electronic cleaner spray...the thought didnt cross my mind till it was mentioned....contacting the wires with a q-tip might be a mistake after all. :o
Originally Posted by jordans30
Guess I must have some rather odd rubbing alcohol then...the label on mine states "70% ethyl alcohol (denatured)"
