Alky/water injection guys
Old Aug 6, 2005 | 07:50 PM
  #31
camcojb's Avatar
Originally Posted by scv8
Jody- Thank you for the input!!
I'm not at 600hp, just the typical 4lb etc. But I'd like to go more aggresive on my timing map and have the piece of mind.
Do you think 18-19* with a 4lb pulley and 93 octane would be safe (with the Boost Cooler that is)?
I read that you went away from straight h20 because of some surging at part throttle boost. Do you think the solenoid for syphoning might help that, or is it programed to inject under those conditions anyway.
Thanks again for so much help!
I was running 18-19 degrees with 14 psi and 91 octane, so I'd say with 93 it's pretty safe. I did ramp the timing though, not all 19 degrees at once.
Jody
Old Aug 6, 2005 | 07:54 PM
  #32
camcojb's Avatar
Originally Posted by typhoon43
If the tank will last longer than one tank of gas then that would be agreat refill interval. Casn someone give me an estimate of how much $$ it is to fill their resevoirs each time? Is it straight alc or alc/water mixture?
Thanks guys. This is definitely looking to be my next mod.
I get 3-4 tanks of gas out of one tank of alky. But if you drive with your foot on the floor all the time your usage would go up. A tank is about 1 gallon and would cost about $2. if you use Snows recommendation of 49/51 alky to water. They recommend methanol which is $3-$4 per gallon, and you'd use about 1/2 a gallon plus 1/2 gallon of water to fill the tank. The cost to run the system is a non-factor in my opinion, especially compared to mixing Xylene or race gas. Now I am still a BIG believer in race gas and toluene/Xylene, but for a daily driver I think the alky is THE way to go. Costs almost nothing and allows timing that nearly equals race gas.
Jody
Jody
Old Aug 6, 2005 | 09:15 PM
  #33
typhoon43's Avatar
Thanks Jody. I'll start eyeing the SMC kit. I like the low fluid warning.
Old Aug 6, 2005 | 09:34 PM
  #34
camcojb's Avatar
You can get that with the Snow kit also, just an FYI.
Jody
Old Aug 11, 2005 | 07:17 PM
  #35
scv8's Avatar
Jody,
I assume you're running a MAF extender........does the Snow MAF controller have any problems with this? Does the controller adjust flow by itself, or do you tune it?
I noticed most people have the nozzle mounted in an aftermarket elbow. Would the OEM elbow work as well?
Thank you!
Old Aug 11, 2005 | 07:50 PM
  #36
camcojb's Avatar
Jody,
Thank you!
I run the SCT Big Air maf. The kit is adjustable for initial on voltage and full on voltage (controls pump speed). So it would work with a stock maf, SCT unit, or maf extender; anything with a 5 volt reference wire.
You can install the nozzle in the stock rubber boot; that's initially how I had mine before I bought the C&L unit.
Jody
Old Aug 12, 2005 | 07:04 AM
  #37
scv8's Avatar
Thank you sir! I think Snow should sponsor you. I'll bet you'll be responsible for turning a great deal of owners on to this.
Old Aug 12, 2005 | 10:25 AM
  #38
camcojb's Avatar
I have sent a few guys their way! Good product, nice to be able to recommend a company like that. Plus I spend WAY too much time online!
Jody
Old Aug 12, 2005 | 10:48 AM
  #39
NorCalLightning's Avatar
Jody
Yep!
Old Aug 17, 2005 | 11:20 PM
  #40
SVTJAY's Avatar
Snow Kit Install
Dual Nozzles
Old Aug 17, 2005 | 11:21 PM
  #41
SVTJAY's Avatar
Tank And Pump mounted in the bed of the truck. this is the larger 7 quart tank
Old Aug 17, 2005 | 11:23 PM
  #42
SVTJAY's Avatar
Solenoid to prevent siphoning
MAF Controller in center console
Old Aug 18, 2005 | 08:07 AM
  #43
scv8's Avatar
Jay- That is one SWEET install!!
I'll be doing this in a week.
*Is there a way to wire an LED, mounted in the cabin, that illuminates when the pump is running with the Snow kit?
*Any tips on mounting the injector into the stock intake elbow without leaks?
*What MAF voltage are you guys using to initially activate the pump?
Thanks to Jody and Jay for all of the help!
Old Aug 18, 2005 | 08:10 AM
  #44
scv8's Avatar
subscribe.
Old Aug 18, 2005 | 09:00 AM
  #45
SVTJAY's Avatar
Yes there is an LED mounted in the Dash I just didnt take a picture of it! This install is in a friends truck, still working on the tuning for it. So its constantly being played with right now to get it set right. Not sure about mounting it in the rubber boot, that might be a problem as they want you to Drill and tap to thread the nozzle in.
