Need help on PI converter install
Old Jul 24, 2005 | 12:22 PM
cclaysvt's Avatar
Question Need help on PI converter install
I'm installing a PI converter and they supply you with 6 bolts The bolt heads look small compared to the holes in the flex plate. Are there supoosed to be
washers that go along with those bolts? They almost look like they'll pull through the flex plate. Has anyone seen this before?
Clayton
Old Jul 24, 2005 | 12:28 PM
lightninquick's Avatar
i reused the old ones,,,,,,,,,,been 15k miles since
the old ones looked alittle safer to me
Old Jul 24, 2005 | 12:32 PM
cclaysvt's Avatar
The stock converter had studs that went through the flex plate with nuts.
the Pi converter has no studs, it has threaded holes and they give you bolts
to install.
Old Jul 24, 2005 | 12:33 PM
hmmm, i dont remember that
i have taken my trans down a few times
Old Jul 24, 2005 | 12:35 PM
i would get some better lock nuts from an auto parts store.
the motor is internally balanced so wieght is not an issue
