Ok I've got it down to two choices...
I want to get a new catback setup and catted mid pipes:
For catback I have it narrowed down to JDM SB or Magnaflow.
Currently, I have the following Magnaflow muffler welded into my stock pipes: 14468
Will the full Magnaflow catback be louder than this muffler? The setup I have now is just too quiet and I want mean/loud. Which is louder (JDM or Magnaflow) and which is a better $$
Is the dual magnalfow setup louder than the single setup?
If I understand correctly, JDM is dual and Magnaflow is single.
Which Cats should I go with? I'm keeping the stock manifolds, can I cut the stock cats out and weld some new ones onto the stock pipes? If so what cats should I get? I have a local shop that does great work if I just supply them the right parts.
Otherwise, what is the best midpipe w/ cats?
Thanks,
I apologize if you are sick of seeing these types of posts...I just want to make sure I get the loudest setup I can afford and I want it to sound mean as heck!
Thanks,
Originally Posted by simmy711
Why the switch to the SB? I'll take it for sure!!!
Gotcha...I had too much to drink last night and I'm a little slow this morning. LOL. What about cats? I the SB is louder then that's the way I'll go.
i have the high flow cats and the single magna flow
it is to loud if you ask me or my nieghbors
its only REAL loud when you get into the throttle (95% of the time)
but what the hell i'm getting older and i probably wont hear it soon
Has anyone just cut the old cats out and has some new ones installed with bent pipe? That's my plan @ least. To get the JDM $88 cats and weld them in place of the stock pipes.
Ok thanks...I think I'm going to order tomorrow. JDM sells the cats for their system and I was thinking of having a shop cut off my existing cats and welding the high-flows in place. Did you get new midpipes with cats or did you cut out the old and weld in new?
I got new mid pipes and cats when I got my Long Tube Headers.
Stock maniflods not sure how you would go about it.Not sure if they sell a high flow cat set up for stock manifold.never went that route I sure someone on here has.
