intercooler cleaning Q
Old Jul 23, 2005 | 10:59 PM
iRideSVT's Avatar
I know i should have thought of this earlier but i spent the day cleaning my i/c,then i put it all together and now dont know what kind of intercooler fuild i need to put in. Someone please help my retarded azz out. Thanks
Old Jul 23, 2005 | 11:26 PM
dealerjim's Avatar
50/50 mix of anti-freeze and distilled water.
Old Jul 23, 2005 | 11:27 PM
iRideSVT's Avatar
Thanks, but how do you know how much is 1/2? How much fluid does it hold total?
Old Jul 23, 2005 | 11:34 PM
2000L's Avatar
If you pre-mix the coolant and water at 50/50 ratio you dont have to worry about the system capacity. Whatever you poor in it is at a 50/50 mix.
Old Jul 23, 2005 | 11:42 PM
iRideSVT's Avatar
Thanks you sooo much, you guys are the best!!!
Old Jul 24, 2005 | 04:50 AM
Big Shooter's Avatar
i did my yeasterday but i didnt use distilled water could this be an issue?
Old Jul 24, 2005 | 09:46 PM
NCsvt2003L's Avatar
Distilled water just doesn't have the impurities that regular water has in it. Don't forget to add a bottle of water wetter, too. You could get away with 25/75 coolant/water in the summer time. Won't hurt the system. I know some people who run straight up water in the summer.
Old Jul 25, 2005 | 08:03 AM
ZorPrime's Avatar
they sell 50/50 mix at most part stores now, so no need to by a gallon of distilled water AND a gallon of antifreeze unless youre a mad chemist!
Old Jul 25, 2005 | 08:15 AM
sweetSVT's Avatar
What would happen if you put just the coolant without mixing it?
Old Jul 25, 2005 | 08:34 AM
ZorPrime's Avatar
decreased heat transfer.
Old Jul 25, 2005 | 08:37 AM
rickgig's Avatar
In other words... anti-freeze retains heat and water gets rid of it. That's why some run plain water during the summer... water wetter is a good idea in any case.
Old Jul 25, 2005 | 09:00 AM
ZorPrime's Avatar
yeah stick a bottle of Red Line water wetter in there.
Old Jul 25, 2005 | 10:03 AM
sweetSVT's Avatar
Ok so I should drain mine and add distilled water or water wetter. What exactly is water wetter? Isn't water already wet!!
Old Jul 25, 2005 | 10:20 AM
Master Of Pain's Avatar
Yeah, but Water Wetter breaks down surface tension and allows for more thermal transfer. It really, really works.
Old Jul 25, 2005 | 10:44 AM
sweetSVT's Avatar
I think i am going to give it a try. Does the wetter need to be mixed or is it a substitute for distilled water?
