Homemade Mods
Old Jul 23, 2005 | 11:04 AM
Big Shooter's Avatar
Homemade Mods
just wondering what are some good home mods? you know duct tape and swiss army type stuff on the L. i know about the boost by-pass but im specail as you all know and id over heat fo-sho.
Old Jul 23, 2005 | 12:34 PM
birdy111's Avatar
you can add tubing to your intake.. stock or otherwise. Get a fresh/ram effect. Cheap and easy.... You could do the grille mod if you have 01+ grilles. Paint your break calipers. Little easy stuff like that... Acetone your badges. Thats about all i can think of off the top of my head
Old Jul 23, 2005 | 04:18 PM
so what happens if you acetone your badges? its a solvent so i assume its to take em off?
Old Jul 23, 2005 | 04:20 PM
SILVERLIGHTNING's Avatar
Originally Posted by Big Shooter
you know, duct tape and swiss army type stuff
How about Cardboard and Zip-Ties?
FF
Old Jul 23, 2005 | 04:38 PM
bwkelley76's Avatar
Intake Tubing
I like the tubing ideas, I did it on my 5.0 and it made a huge difference. Just look around at Hardware stores, just make the tubing smooth and no harsh or abrupt bends. Superchargers LOVE fresh-cold air, and lots of it.
Old Jul 23, 2005 | 04:51 PM
bwkelley76's Avatar
here's another cool idea...
a friend of mine did this on his turbo'd car, he took the washer bottle, and ran the squirters into the front of the intercooler, and put ice in the reservoir with water. now you'll have to run a seperate swich unless yo uwant your wipers to go on with the existing switch. he said it worked good. I've never tried it myself. Maybe put some fans in fron of your intercooler, but I would do one or the other, you don't want the water shorting out your fans.
Old Jul 23, 2005 | 04:56 PM
bwkelley76's Avatar
Radiator Fans
Get rid of the fan and clutch, and retrofit a couple of electric ones, or buy them made to fit. Been told it's a BIG difference. I can feel the engine bog down when the fan clutch kicks in on my L.
Old Jul 23, 2005 | 09:17 PM
l-menace's Avatar
https://www.f150online.com/forums/sh...&highlight=fan
Old Jul 23, 2005 | 10:04 PM
brain bypass's Avatar
acutally, you could do something similar. get a small cooler and 25' of copper hose. drill 2 hole through the cooler and put the coli of tubing inside it with each end running out through the holes. the hook this up in line with the line going to the intercooler in the block. mount the cooler in the bed. fill it with ice right before you run. it wount last long though, 1 maybe 2 runs. it works the best in the heat. on a cool winter night, i doubt there would be any real gains. do a search on here for "powercooler" for more details.
i am making a box out of fiberglass to mount under the hood to do the same thing. total cost so far: $50
do this also, then run some 4" dryer hose to it and the other end to a scoop either behind the grille or under the front bumper:
http://www.nloc.net/forum/showthread...ghlight=airaid
Old Jul 25, 2005 | 11:38 AM
rickgig's Avatar
acetone takes the black off of your badges... it'll also take your paint off your exterior if you are not careful!!
Old Jul 25, 2005 | 12:47 PM
i am not a fan of acetoned badges, it looks like they are old and the paint wore off.
now if you were to acetone them, and then repaint them to match the color of your truck (obviously if you truck isn't black) that would be sweet
Old Jul 25, 2005 | 01:23 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
... it'll also take paint off your exterior if you are not careful!!
Sometimes that's your only recourse if you don't obey 'Wet Paint' signs.
