Help!!
Old Jul 20, 2005 | 05:14 PM
OD1010's Avatar
Help!!
I feel like an absolute idiot when i ask this question but i need the calibration code for my truck and I know its on the computer but where is the computer?!?! I was told the code is a 4 digit code found on a white sticker on the computer. I need the code ASAP so any help would be greatly apprecitated. Thanks alot in advance for fielding this stupid question.
Old Jul 20, 2005 | 05:45 PM
Silver-Bolt's Avatar
Just a thought, but why not pull the computer on look???
Old Jul 20, 2005 | 05:52 PM
chimshady1's Avatar
Because hes asking where the computer is. The computer is located by the passenger kickpanel. Look under your glovebox to your right. I believe its a 10 mm bolt that holds it in under the hood (passenger side) on the big wire harness. I also think the ecu sticker is in the passenger door jam although i might be wrong.
Old Jul 20, 2005 | 11:36 PM
Don's Bolt's Avatar
Yes you are right
If you do remove the computer, disconect the battery. Yes there should be a sticker on the pass door jam, also one on the computer
here is the 03 code NLP2
