Intercooler Pump toasted ...
Old Jul 17, 2005 | 05:53 PM
SVT_KY's Avatar
Lightbulb Intercooler Pump toasted ...
62K and I don't know how long it hasn't been running. I wonder
if that could contribute to my eating spark plugs in #5 cyclinder?
Why doesn't a pump not running throw a SES light? Surely there
is something (IAT2 TEMP) that would let us know.
So if you have some mileage on the beast, best check to see that
the pump is running. I know that's why my last few outings have
had less than stellar results.
Cliff
PS... I found the pump for $91.00 on the Net.
BOSCH PART NUMBER 0 392 022 002
VW PART NUMBER 034965561C
A1 Part Number 58589 (I think!!!)
Old Jul 17, 2005 | 10:16 PM
BlueOvalBolt's Avatar
How did you find out your pump wasn't running?
Old Jul 17, 2005 | 10:46 PM
SVT_KY's Avatar
The coolant wasn't churning in the I/C reservoir. Then I hot wired
it from the battery to verify ... after removing it, it was LOCKED up tight.
The pump impeller turned freely, it was the DC motor that was toasted.
Old Jul 17, 2005 | 11:41 PM
LatemodelRacer2's Avatar
could you hook a brother up on the site where i can get the pump?
Old Jul 18, 2005 | 06:30 AM
bwkelley76's Avatar
pump running??
when does the pumo run anyways? is it hooked inline with some sort of thermostat or does it run all the time with the K.O.E.R.? KOEO? I've always wondered if that puppy is runnin or not?? BK
Old Jul 18, 2005 | 06:46 AM
SVT_KY's Avatar
Wrong pump .... Sorry
Old Jul 18, 2005 | 12:29 PM
rickgig's Avatar
Hey guys... the easy way to know the pump locked up is that it runs like a dog after you've been on the road for more than 20 minutes.
The easy fix until you get a pump/motor in is to hit the motor with a plastic hammer a few times. Mine locked up twice on me and I have been putting off buying the pump... First time someone told me to hit it and sure nuff... it worked. Second time all I had to do was shut the motor off and restart.
Been like this for 4 months now. I know.. I better buy a replacement cause one day it'll lock up for good.
Old Jul 18, 2005 | 03:20 PM
SVT_KY's Avatar
minutes.
Well, I couldn't turn mine with a 6" Channel-Lock ... So I don't think
pounding is a good solution. < grin > For $91 I am gonna keep a
spare in the "road race" parts bin ...
Old Jul 19, 2005 | 08:46 AM
bwkelley76's Avatar
Still curious...
SO guys, it normally runs all the time with the key on????
Old Jul 19, 2005 | 01:58 PM
Check this thread out:
http://www.nloc.net/forum/showthread...highlight=pump
Old Jul 19, 2005 | 02:17 PM
lurker's Avatar
There's a timer that keeps it from running for the first ~20 sec after you start the truck. It also won't run if IAT2 is below ~60*.
Old Jul 19, 2005 | 02:28 PM
I'm pretty sure it under 40*, not 60*.
Old Jul 19, 2005 | 04:28 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Come on Cliff, you know you want to use the BFH fix.
Old Jul 19, 2005 | 05:16 PM
SVT_KY's Avatar
Bobbert, I DID use the BFH ... it didn't change a thing !!!
I'm waiting for UPS to deliver my overnight pump as I type ...
Old Jul 19, 2005 | 07:33 PM
SVT_KY's Avatar
Well, apparently VW PART NUMBER 034965561C
yields a BOSCH 0 392 020 054 (At least that is what the invoice says!)
This is about half the size of ours, but might work in a pinch.
The FORD part is F8YH 8501 AA in case you were wondering ...
I found the BOSCH part number under a strategically placed piece of tape.
grrrrrr....... I might have to BUY the ford one at 392 !!!!
Some of my racing buddies suggested using a 12 Volt BILGE PUMP ... Might try that too
