intake hp Q
Old Jul 8, 2005 | 06:58 PM
svtdemon's Avatar
intake hp Q
i just got the aem brute force intake for my 01 lightning does anyone know how much hp i gained
Old Jul 8, 2005 | 07:25 PM
Suavy's Avatar
I never heard of it?
Peace,
Suavy
Old Jul 8, 2005 | 07:26 PM
mike00L's Avatar
-5hp lol
Old Jul 8, 2005 | 10:14 PM
LAGAININ04's Avatar
See the attached PDF I got off the AEM company website. They claim the following:
Largest Gain: 21.7 hp @ 2500 RPM and 37.4 ft-lbs @ 2500 RPM
I have the Brute Force. I haven't run on a dyno so don't know what I'm running. I do know though it sounds and looks great.
http://www.theroadrunner.com/lightning/aem.pdf
Jeff
Old Jul 8, 2005 | 10:30 PM
LightningTuner's Avatar
Be careful with that intake. It actually replaces the MAF and alters it. I've seen lots of trucks have problems with that setup, if you don't have a tune to correct for it.
Old Jul 8, 2005 | 10:34 PM
Robert Francis's Avatar
There's all kinds of "claims" in the adverstising for the "intake kits" from all the suppliers - unless you've got several modifications that require more "air" or your original stock airbox had a clogged filter - about top of line hp pickup might be 4-5hp - maybe.
Old Jul 8, 2005 | 10:37 PM
Pay attention to what "Sal says:" he's usually right on!
Old Jul 8, 2005 | 11:50 PM
l-menace's Avatar
I was just going to say that...
Old Jul 9, 2005 | 12:12 AM
Fast95Z's Avatar
How does it alter it? It is identical to the stock one.
Old Jul 10, 2005 | 02:07 AM
OD1010's Avatar
i have the brute force intake and a bassani catback and mid pipes on my 03, i have never had a problem with the intake and i just got dynoed today and it read 370hp and 443tq at the wheels.
Old Jul 10, 2005 | 02:25 AM
Spanky99L's Avatar
do you reuse your stock MAF electronics? if so you are running 80 or 90mm electronics in a larger tube diameter tube thus not getting a correct reading of incoming air thus running lean.
Will
Old Jul 10, 2005 | 02:31 AM
Fast95Z's Avatar
Will
wrong. it is the same 90mm diameter as the stock piece.
Old Jul 10, 2005 | 03:05 AM
Spanky99L's Avatar
well it looks like you need to relearn your metric system conversions. aem advertises a complete 4 inch intake tube. do your conversion to mm and it comes out to 101.6mm. way larger than stock.
Will
Old Jul 10, 2005 | 03:16 AM
Fast95Z's Avatar
Will
I have the intake and I measured it along with put the stock one up to it and took pics of it. Despite what you may have read or heard it is wrong. They are identical. Both are 90mm. Also show me where AEM says it's a 4" pipe. It's certainly not on their site.
Old Jul 10, 2005 | 04:59 PM
Spanky99L's Avatar
AEM Intake
read 4 inch massive piping
Will
