Q-Logic Kick panels
Old Jul 8, 2005 | 05:22 PM
baddgene's Avatar
Q-Logic Kick panels
I know some of you are running these in your L's. Did anyone run into a problem using the park brake? If I depress mine all the way, the pedal will dent the panel.
Old Jul 8, 2005 | 05:25 PM
brain bypass's Avatar
bend the pedal so it will clear it. that is what i am going to do. i ordered mine today, i didn't feel like doing the 'glass work to make my own right now.
Old Jul 8, 2005 | 06:21 PM
St Louis Lightning's Avatar
Make sure you have mounted the back screw hole in the right place. The pod needs to fit as far back and over to the exterior as possible. I can depress my parking break without damaging the pod. It barely touches the grill.
Old Jul 8, 2005 | 08:22 PM
jordans30's Avatar
Will the enclosures for the '97-'00 F150s fit an '02 L?
Old Jul 8, 2005 | 10:47 PM
yes.
Old Jul 9, 2005 | 03:45 AM
baddgene's Avatar
Thanks, I'll check it out.
Old Jul 27, 2005 | 04:14 PM
joecey's Avatar
I havent been able to use my ebrake. Im pretty sure its mounted all the way back. I think that we need to bend the bracket.
