Self porting results needed pls
Old Jul 4, 2005 | 10:11 PM
IronmanSTL's Avatar
I know a few guys ported the supercharger themselves...
I was just wondering what you followed for a template, and what hp/torque increase (or decrease) you saw at the dyno?
thanx in advance
Old Jul 4, 2005 | 10:15 PM
NCsvt2003L's Avatar
I used the steig. design. We also port matched the upper inlet to the gasket and used a extrude honed upper intake plenum. Gained a couple of PSI. This was done and installed on a built motor running a #8 lower with the heads done.
Old Jul 5, 2005 | 09:21 AM
brain bypass's Avatar
i did a similar design to the steg. on the outlet. and spent countless hours smoothing out the intake side. then gasket matched the inlet, and the plenum.
no dyno results, and i did this when i put in the new motor, so without swapping the stock one back on, it will be hard to get reliable dyno results.
