Fuel Pressure ?
Old Jul 4, 2005 | 10:06 PM
NCsvt2003L's Avatar
Question Fuel Pressure ?
Ok, just installed twin 255 fuel pumps. At idle, I am only seeing 27 psi on the guage vs 29-30 with my stockers. Is that normal for you guys that have these? Any way to increase it or just leave it alone. Now at WOT it shoots up to about 50 right away. The old one it would shoot up to 40 at partial throttle, these don't, just sit at around 32 psi. Mods in sig. I installed these for the KB I am getting. Thanks Ronnie
Oh these are 255 Walbro's from LFP.
Old Jul 5, 2005 | 02:14 PM
NCsvt2003L's Avatar
anyone?
Old Jul 5, 2005 | 02:20 PM
Sharpshooter's Avatar
Originally Posted by LightningTuner
Yes the issue has been solved. The problem was that the 255s are of a design of pump that doesn't like low voltage. When they have normal voltage (i.e. WOT on the Lightning), they flow to their specified capacity. But when they are at the lower stepped voltage, they actually flow less fuel than the stock pumps. Now this is perfectly fine for a stock truck, as they still supply enough fuel for the regulator to maintain base fuel pressure. The problem comes when you have larger rails. Then the pumps do not move enough fuel under stepped voltage to keep the rails full. That's where the low fuel pressure issue comes from.
The solution? Buy a second fuel pump dropping resistor, and wire it in in parallel with the original. That changes the stepped voltage from 7 volts to about 9 volts, and then the 255s move enough fuel to make it all happy again.
Hope this helps.
Found in this thread
Old Jul 5, 2005 | 02:40 PM
LightningTuner's Avatar
On a truck with stock fuel rails, you can leave it as is. It will all work as original, except for the higher volume when at WOT.
Old Jul 5, 2005 | 08:39 PM
NCsvt2003L's Avatar
Thanks guys! I plan on putting a KB. Maybe I got the wrong pumps. I'll check.
Old Jul 5, 2005 | 08:55 PM
NCsvt2003L's Avatar
Alright here is the fuel pump # GCA719-2. I know they have another that is a High Pressure model, too.
Old Jul 6, 2005 | 07:20 PM
NCsvt2003L's Avatar
Sal, tried calling you today to get the right pumps. I left a message with my #.
Old Jul 6, 2005 | 08:58 PM
NCsvt2003L's Avatar
ttt
Old Jul 25, 2005 | 09:42 AM
brain bypass's Avatar
Hope this helps.
anybody have a part # for the step down resistor?
i am having the same problem with my 255's i put in yesterday.
Old Jul 25, 2005 | 03:13 PM
NCsvt2003L's Avatar
You got the wrong 255's. Send them back and get the right ones.
Old Jul 25, 2005 | 03:22 PM
they are already in the tank though.
Old Jul 27, 2005 | 09:58 AM
picked up a fuel pump resistor and wired it in parallel as Sal said to, and now they work fine. it got it from my parts hookup for $24
ford part # f81z-14a601-ac
