Temp sender in resevoir ok?
Old Jul 1, 2005 | 12:36 PM
SMELTZ's Avatar
Would it be a good location to drill and tap into this alum. resevoir? I have a defi coolant temp guage and want to install the sender here, but I don't know if that is good location or not. Any advice would be appreciated, THanks!
Old Jul 1, 2005 | 02:04 PM
JollyGiant's Avatar
Water does not circulate thru the reservoir, it acts as an expansion tank for the coolant so it would not be a very good place for the temp sensor.
It would have a slow reaction to temperature changes if it were located in the tank.
Old Jul 1, 2005 | 10:27 PM
meansvt00's Avatar
is that the intercooler tank or the rad overflow tank. if it is the intercooler tank it would work because the fluid flows from the aftercooler to that tank before it goes to the heat exchanger but if its the rad tank it wouldnt work as stated above.
Victor
Old Jul 2, 2005 | 12:32 AM
SMELTZ's Avatar
Thanks for the clarification regarding the two tanks. Which is the more important measurement, intercooler temps or water temps?
