Predator Timing adjustments question
Old Jun 30, 2005 | 11:35 AM
Sharpshooter's Avatar
There are 2 different adjustments.
Global Spark Adder -6 to 4degrees add or subtract
Timing Table (+10/- 40%)
Which one would I use if I just wanted to add timing during WOT? I don't want to mess with PT or anything else just WOT.
Old Jun 30, 2005 | 11:40 AM
LightningTuner's Avatar
Use the Global adder. It will adjust timing everywhere, but 2-3 degrees will have little to no effect on part throttle stuff. If you use the Global adder it will "definitely" add/subtract that amount of timing, no matter what is programmed on your tune. If you use the timing tables, it may not add the timing depending on how your tuner has set the tables up.
